So, back in July, I got the MSI GT72 2QE. I love this laptop dearly. However, in the last week or two, an issue has come up: the plastic has begun to separate at the bottom-left hinge. Normally I can "snap" it back together, and it mostly only happens when I open the laptop, but it's getting concerning. If I don't hold that point firmly as I open it (my current solution), the laptop makes an uncomfortable "cracking" sound.
I am fairly sure no internal components are being damaged, as far as I can tell this is just the outside plastic.
Before I break out the tools or super glue, or whatever the correct solution would be...suggestions?
My Build, "Helios"
CPU: 5950x with Noctua NH-D15
GPU: MSI 2080ti
Case: BE QUIET! Dark Base 900 Pro
Storage: Samsung 970  pro 500gb (boot drive), unknown 2tb Seagate drive, 4tb WD Black drive
PSU: Corsair HX1000i
RAM: (4x8) Trident Z RGB
Remote PC Starter Kit
https://linustechtips.com/topic/545772-msi-gt72-2qe-hinge-issue/
Don't fiddle with it yourself, contact MSI support for warranty repair.
I had this same problem with a HP laptop a few years ago, at the time it was older than the two year warranty, so i used super glue aswell to get it back together.
It worked for a while, untill the hinge got fixed into position and i couldnt open the darn laptop.
So , first contact MSI support, please :P
"I fart in your general direction" -The Frenchmen
https://linustechtips.com/topic/545772-msi-gt72-2qe-hinge-issue/#findComment-7216968
...I honestly did not even consider contacting MSI on the issue :P This is probably the best call...thank you!
My Build, "Helios"
GPU: MSI 2080ti
https://linustechtips.com/topic/545772-msi-gt72-2qe-hinge-issue/#findComment-7216977
