Phone stuck truning on
Go to solution Solved by Nacho Marco Segui,
3 minutes ago, TubsAlwaysWIns said:
Power+Volume down is generaly the main set of buttons, which I have tried
Try volume up and power
Title basically says it all. I plugged in my phone last night to charge and this morning its stuck on the Verizon screen. What do i do? The power and volume buttons do nothing
I have the HTC One M9
Edited by TubsAlwaysWIns
Breaking things 1 day at a time
https://linustechtips.com/topic/545751-phone-stuck-truning-on/
What phone do you have?
// Floatplane Pilot //
Main Rig:  Motherboard: ASUS H270 - PLUS - CSM | RAM: Corsair Vengeance DDR4 16GB (2x8GB) | Case: Corsair Carbide Series SPEC - 02 | SSD: ADATA SU800 128GB HDD: WD 1TB Hard Drive | PSU: Corsair CX 550M | CPU: Intel Core i7-7700 Cooling: Cooler Master Hyper 212 EVO | GPU: ASUS GeForce GTX 1070 | Keyboard: Logitech G710+ Mechanical | Mouse: Razer Naga 2014 | Sound: Corsair VOID RGB / USB Headset | OS: Windows 10
Laptop:   Razer Blade Stealth 2016
https://linustechtips.com/topic/545751-phone-stuck-truning-on/#findComment-7216716
Just now, TubsAlwaysWIns said:
HTC One M9. Should have mentioned that, sorry
Try taking the battery out and putting it back in, then proceed to turn it on.  If it still doesn't work let me know.
https://linustechtips.com/topic/545751-phone-stuck-truning-on/#findComment-7216729
Have you tried booting it into safe mode?
https://linustechtips.com/topic/545751-phone-stuck-truning-on/#findComment-7216766
46 minutes ago, TubsAlwaysWIns said:
@Nacho Marco Segui @ShadowDeity Its working now. Thanks
No prob, how did you get it to work?
https://linustechtips.com/topic/545751-phone-stuck-truning-on/#findComment-7217135
