4 minutes ago, Hectr34 said:
Hi guys, just got a 4790k and im getting 78 degrees celcius on p95. Seems high to me since my 9590 at 5ghz never went over 55 and that thing is power hungry!  Im using a Kraken x61 to cool it down.
Not really safe. Did you overclock it?
https://linustechtips.com/topic/545554-4790k-temps/#findComment-7214675
Welcome to the Forums!
For Haswell it's best to not use P95 it tends to overdo it on the stress testing giving unrealistic results, Adia 64 pr Realbench would be better options.
https://linustechtips.com/topic/545554-4790k-temps/#findComment-7214722
Have you applied new paste on the cpu or did you use the paste left over from the 9590? Also what kind of paste did you use?
SYSTEM: CPU-i5-6600k GPU-EVGA Titan X SC MOBO-Asus Z170-A SOUND CARD-Asus Xonar Essence STX RAM-16GB HyperX Fury 2133 DDR4 COOLER-CoolerMaster Hyper T4 WIFI-Asus PCE-AC68
https://linustechtips.com/topic/545554-4790k-temps/#findComment-7214786
