Java-How to sort 3 numbers without if statements
What's up guys,
I'm wondering if there is some kind of command that allows me to sort 3 integers from least to greatest. I know I could use if statements but I feel like I could condense my code with a command like this. In python I know it was like sort or something. Thanks for the help in advance.
Use  sort() from Java.util.Arrays
int v[] = {2, 1, 9, 6, 4};
Arrays.sort(v);
for (int i : v) {
   System.out.println(i + " ");
Arrays.sort(v);
for (int i : v) {
Thank you, I can add custom integers with the scanner correct?
Yes.
You could also do this , but it's pretty much the same thing as using if statements :
int a , b , c;
read();
System.out.println( (a>b&&b>c?c:(a>b&&c>b?b:(b>a&&c>a?a:-1)))+ " " + (a>b&&a<c||a>c&&a<b?a:(b>a&&b<c||b>c&&b<a?b:(c>a&&c<b||c>b&&c<a?c:-1))) + " " + (a>b&&a>c?a:(c>a&&c>b?c:(b>a&&b>c?b:-1))));
14 minutes ago, Nineshadow said:
Yes.
int a , b , c;
read();
Thanks, I'm getting an error with read(); line.
Obviously. It's a placeholder since I couldn't remember how to read stuff in Java .Just read into the numbers .
Sorry to bother you again, but if I enter a small value as number three it outputs a negative 1.
import java.util.*;
import java.util.Scanner;
import java.util.Arrays;
public class Sorter
    public static void main(String[] args)
        Scanner keyboard = new Scanner(System.in);
        int a, b, c ;
        System.out.println("Hello, please enter 3 numbers so that I may sort them.");
        System.out.println("Please enter Number 1:");
        a = keyboard.nextInt();
        System.out.println("Please enter Number 2:");
        b = keyboard.nextInt();
        System.out.println("Please enter Number 3:");
        c = keyboard.nextInt();
import java.util.*;
public class Sorter
        int a, b, c ;
I would highly suggest using an array for this, sorting, and then displaying it.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
If this is for school, I wouldn't recommend going with this method. It looks like a copy/paste so it may lose you marks/get you a zero depending on if that kind of thing is considered cheating or not. The marker likely won't believe you wrote this yourself. If they asked you to explain it to them, could you?
Also, even if they wouldn't lower your marks for that, if the work is graded in any way on readability it's likely to do poorly.
If it's not for school/doesn't matter then I guess you're free to do whatever.
