Work PC sounds shitty
Hello! I enjoy music while I'm working.
But the PC I use at work really has shitty sound.
I'm using a pair of Harman Kardon Soho II that I plug into the front jack.
But the sound is so bad! It's tinny and barely worth listening to.
Is there anything I can do? I'm not allowed to open up the pc and plugin a card or such.
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/
USB DAC/AMP
https://www.komplett.se/product/830580/ljud-bild/horlurar/tillbehor/fiio-e10k-olympus-2
it's plug and play so don't even need to install anything.
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/#findComment-7207915
3 minutes ago, ZetZet said:
USB DAC/AMP
It's a bit pricey for work hehe. How kind of you to link to a local website ;)
2 minutes ago, oldkingdragonslayer said:
Could always use a mp3 player/ phone
That's probably the way I have to go. But I'd like to control the music via the computer. But it's no biggie really.
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/#findComment-7207929
well you can carry it home
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/#findComment-7207961
8 minutes ago, KuJoe said:
Does your work offer WiFi? I have old tablets and phones with no service but work nicely for Pandora. I remember @Slick mentioning in a WAN Show (I think) that he used an app for his phone to control it from his work PC.
Sadly, they do not. I could sneakily plug in a router though...
I have no need for it at home. I guess I'm getting spotify and downloading the music to my phone.
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/#findComment-7207973
38 minutes ago, Donk Quixote said:
Is the battery dead?  Do they sound as bad plugged into another device?  Can you access the back headphone jack?
The battery is not dead, I can clearly hear a difference with it on and off. And it sounds way better on my phone. I do have access, but the cable will be way too short sadly.
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/#findComment-7208710
Just now, Sephirothkefka said:
what kind of computer is it? if its custom, whats the mobo and case?
I'm not at work right now so I can't check.
I know it's an HP prebuilt. Imagine the shittiest prebuilt HP with an i3. The case is smaller than a standard tower.
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/#findComment-7218191
It might have either idt or realtek. idk how shitty idt is but sigmatel is one of the best imo. Realtek is VERY hit or miss. I'd disable any equalizers in the realtek and windows control panels and increasing the sampling rate from 16 bit 44100 hz to 24 bit 192000
SYSTEM: CPU-i5-6600k GPU-EVGA Titan X SC MOBO-Asus Z170-A SOUND CARD-Asus Xonar Essence STX RAM-16GB HyperX Fury 2133 DDR4 COOLER-CoolerMaster Hyper T4 WIFI-Asus PCE-AC68
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/#findComment-7218222
I did increase the sampling rate. I also had to use the equalizer to lower my right ear plug to 75% volume (because they were uneven for some reason).
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/#findComment-7218241
Then it's probably either the player or the files. Are you streaming or listening to it locally? Also what music player are you using?
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/#findComment-7218261
Woops, wrong button.
I'm streaming from youtube.
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/#findComment-7218273
Yeah....
It's best to listen to them locally and using 192 kbps mp3s at the minimum. TBBH, streaming sucks :P
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/#findComment-7218289
Yeah....
It's best to listen to them locally and using 320 kbps mp3s. TBBH, streaming sucks :P
Haha well it's either stream from youtube or listen through my phöne.
I did just get spotify though so I will use that on my phone :) Thanks for helping! Also, my inbox is now filled with dancing skeletons. I love it.
https://linustechtips.com/topic/544954-work-pc-sounds-shitty/#findComment-7218301
