Weired BIOS problem
Go to solution Solved by evilarceus,
Reset BIOS? :P
Hello, so today I tried to overclock my FX-8120 cpu on my Gigabyte 990FXA-UD3 rev.3 Motherboard. I didnt thought too much about it and just played around a little because the MoBo has dual-bios, not that smart, i know.... when i saved and exited the Bios,my pc turned on properly, but when I logged into windows, my pc shut down. I tried restarting and then my Pc would crash a little earlier. when i tried to enter my bios the 3rd time I restarted, it would crash a couple seconds after i'm in the BIOS. After that i tried everything again and it here are the results: It crashed a couple Seconds after i enter the BIOS, it chrashes when i try to enter the bios, windows is reporting a proplem and suggesting to restart, it crashes right after it loaded my windows-desktop.
I tried to Q-Flash the motherboard but the USB-stick i had the BIOS on wasn't recognized. My RAM is Corsair Vengeance with1600mhz and 9-9-9-24 timing.
I hope you guys can help me.   BTW. i don't have another MoBo, RAM or CPU to switch around.
https://linustechtips.com/topic/544723-weired-bios-problem/
Reset BIOS? :P
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
https://linustechtips.com/topic/544723-weired-bios-problem/#findComment-7205259
