So, this is a bit of an odd question...
I have an old cooler from my 980, and I want to put it up as decoration. I would like to possibly power up the fans and the LED's on the cooler.
Does anyone know where I can get some adapter cables to achieve something like this?
Picture of the connectors:
Specs:
Intel i7-4790K @ 4.7 GHz cooled by Corsair H80i | ASUS Maximus VII Formula |  G.Skill 8 GB (2 x 4GB) 2133 | EVGA 980 Superclocked (Fry) | 128GB Samsung 840 Pro OS Drive | WD Black HDD | 500GB Samsung 850 EVO | Corsair Vengeance K70 | Logitech G502 Proteus Core
lol @ AMD 8350
https://linustechtips.com/topic/544565-graphics-card-cooler-cables/
why cant you just cut the connector off and connect the cables directly to power?
Because I have never ever done anything like that, and I'd rather not risk something like that if there's a cable that exists...
Specs:
lol @ AMD 8350
cutting and stripping a cable is not hard
just look at youtube tutorials
you dont even need to solder anything if you dont want to, just twist the wires to a power source
GPU cooler -> Fan Controller -> AC adapter
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
Or now that I think about it, GPU Cooler -> ATX fan 3/4pin to molex adapter -> molex to ac adapter
Oh sweet good god, I hooked it up to my fan controller and it goes ham.... Thanks TidaLWaveZ, I wasn't aware that I was actually able to do that.
Specs:
lol @ AMD 8350
