I am really considering water cooling once again.
Ive seen alot about swiftechs expandable liquid coolers.
Do I void my warranty by doing this?
How many blocks / rads can the pump push through.
Any more i need to know before doing this?
I think of buying a fury x to watercool together with my 4690k
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/544398-swiftech-liquid-cooler/
You void your warranty by (attempting to) pulling the pump apart or removing it from the built-in reservoir.  Simply disconnecting the lines and adding in new blocks, rads, etc won't harm the warranty.
If they follow their usual pattern, Swiftech will have a specific adapter you'll need to buy for the pump's outlet, so that you can add G1/4-threaded adapters to, if you want.  That adapter isn't expensive at all.  The rest of the holes in the system (2 on the CPU block, 1 on the rad/res) are threaded appropriately for G1/4.
As for the number of blocks/rads/etc, I'm not sure.  Swiftech has a great user forum, and one of their support guys (Ren) is super active on it.  He'll probably be able to tell you how many devices the pump on that cooler can manage.
Editing Rig: Mac Pro 7,1
System Specs: 3.2GHz 16-core Xeon | 96GB ECC DDR4 | AMD Radeon Pro W6800X Duo | Lots of SSD and NVMe storage |
Audio: Universal Audio Apollo Thunderbolt-3 Interface |
Displays: 3 x LG 32UL950-W displays |
Gaming Rig: PC
System Specs:  Asus ROG Crosshair X670E Extreme | AMD 7800X3D | 64GB G.Skill Trident Z5 NEO 6000MHz RAM | NVidia 4090 FE card (OC'd) | Corsair AX1500i power supply | CaseLabs Magnum THW10 case (RIP CaseLabs ) |
Audio:  Sound Blaster AE-9 card | Mackie DL32R Mixer | Sennheiser HDV820 amp | Sennheiser HD820 phones | Rode Broadcaster mic |
Display: Asus PG32UQX 4K/144Hz displayBenQ EW3280U display
Cooling:  2 x EK 140 Revo D5 Pump/Res | EK Quantum Magnitude CPU block | EK 4090FE waterblock | AlphaCool 480mm x 60mm rad | AlphaCool 560mm x 60mm rad | 13 x Noctua 120mm fans | 8 x Noctua 140mm fans | 2 x Aquaero 6XT fan controllers |
https://linustechtips.com/topic/544398-swiftech-liquid-cooler/#findComment-7201833
thank you so much :)
Built  Not Bought
https://linustechtips.com/topic/544398-swiftech-liquid-cooler/#findComment-7201847
Thank you for interest our product. Only the X series need a G1/4 adapter for the pump housing. The new X2 series have G1/4 adapter pre-installed. The MCP30 pump can handle up to 1 CPU+2 GPU blocks. This really depend on that block are you using and their restrictions.
https://linustechtips.com/topic/544398-swiftech-liquid-cooler/#findComment-7202380
Thanks for the respond.
Im gonna use the 240mm to cool a 4690k and a fury x, will it work?
Built  Not Bought
https://linustechtips.com/topic/544398-swiftech-liquid-cooler/#findComment-7202484
