Hi guys.
I'm going to build a new pc in a couple of weeks and I've decided on all the parts except for the MoBo.
I'll give you the part list just so you can give me a better idea on what MoBo to buy.
CPU: i74770K
GPU: EVGA GTX 780 Classy
RAM: 2x8GB Corsair Vengeance Pro 1866Mhz, CL9
Cooler: Corsair H100i
Case: Nanoxia Deep Silence 1
PSU: Seasonic 650KM3, it's 650W Gold Efficiency
SSD: Samsung 840 Pro 128Gb
HDD: WD 1TB Caviar Black
So far I've been thinking about the the MSI GD65, but recently I've set my eyes on the Asus z87 PRO, well colorwise it's terrible but it's Asus, and I won't buy a windowed case so it doesn't really matter what it looks like.
Basically I want something in these two cards' pricerange. Any good tips?
https://linustechtips.com/topic/54418-motherboard-options-help/
Both are great motherboards and performance will not be affected depending on which board you choose. Go with whatever would suit your build the most.
https://linustechtips.com/topic/54418-motherboard-options-help/#findComment-730989
I'd go with Asus because it has more USB 3.0 ports(Internal and external), more SATA 3 6Gb/s ports and it has built in wi-fi and bluetooth.
CPU: i5 4670K, Mobo: Gigabyte Z87X-UD3H, RAM: Corsair Vengeance Pro 8GB, GPU: Asus 280X, Case: Fractal Design XLR2, SSD: 840 evo 120GB, HDD: 2x 1TB Seagate, PSU: Corsair RM750, Cooler: Cooler Master Hyper 212 evo
https://linustechtips.com/topic/54418-motherboard-options-help/#findComment-731094
I've decided to go with the Maximus VI Hero :) I think it's the best board in its pricerange
You could go with the cheapest z87 mobo and it wouldn't make any significant difference other than you would save a substantial amount of money.
Also, your build could be cheaper without really losing any performance.
What's the system being used for?
https://linustechtips.com/topic/54418-motherboard-options-help/#findComment-733339
editing/programing/gaming at about 35/35/30 ratio :)
won't make a bit of difference on apps used for the motherboard selection. that's
what is needed for CPU decision.
motherboard questions are:
CPU - overclocking or not
GPU - how many
USB - how many ports needed
iGPU - what i/o is needed for connection, useless for a dedicated GPU unless until
emergency of death of GPU.
WiFi - needed or not
LAN - one or two ports Intel, Killer NIC, or RealTek
SATA - how many SATA III ports needed
color - prolly the most important for build strategy
airdeano
https://linustechtips.com/topic/54418-motherboard-options-help/#findComment-734556
GPU - how many
airdeano
CPU - Overclocking, if not I wouldn't pick a K processor and a Corsair H100i
GPU - Well for now one Evga 780 Classy, later i might add a 2nd one
USB - Well usually any MoBo+case ports should be enough
iGPU - in case of emergency any port will suffice, except Display Port. My monitor doesn't have one
WiFi - Cable is better
LAN - All these new LAN thingies perform basicly the same. So any of them is ok, 1 port is enough.
SATA - For now I'll need 4 but that is going to change soon
Color - Don't rly care, won't be getting a windowed case. Tho the ROG Hero looks ubernice
https://linustechtips.com/topic/54418-motherboard-options-help/#findComment-734821
I would get the Asus Z87-A/ MSI Z87 GD65 Gaming/ Gigabyte GA-Z87X-UD3H. Personally like the Asus one because of its features and its UEFI Bios UI.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/54418-motherboard-options-help/#findComment-737910
Just get the cheapest z87 mobo with sli.
https://linustechtips.com/topic/54418-motherboard-options-help/#findComment-738045
