Operating System not booting up
Go to solution Solved by George Cristea,
Actually a forum administrator CPUK answered me already
#Dodge "In the bios turn off uefi set it to legacy for windows 7 "
Hello
I have bought a laptop from cyberpower PC and just tried to reinstall my windows... from Windows 10 ..To Windows 7 because I don't really feel like using Windows 10 at this moment  .... Well I made a bootable USB drive and tried to reinstall it but each time I do go in the boot menu ... and select my USB.. it just doesn't take it as a bootable USB... it just continues loading up the Win 10 .... ive tried with 2 methods of booting my USB... even tho it was supposed to work straight away.
Microsoft Tool, Command prompt manually and none of them have succeed. on my PC they work.. but not on the new laptop. so .. :/
PS:It shows in the boot menu but doesn't want to load up the files , my opinion..
Any of you have any idea why this might be happening ?
https://linustechtips.com/topic/543967-operating-system-not-booting-up/
How did you make the bootable USB? Did you use the Windows Media Creation Tool from Microsoft? Click here to download the tool
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Ive also tried to use their win10 disk .. well that boots up .. but unfortunately I don't have an empty disk to try booting up on a disk win7 ... so I have wanted to use the USB .. as a faster option .. :/ so is something wrong with the USB option.. I also tried to change from a port to another but is not the case.
Hello
Microsoft Tool, Command prompt manually and none of them have succeed. on my PC they work.. but not on the new laptop. so .. [emoji32]
Is it running skylake if yes, you are out of luck
Also make sure that the laptop that you want to downgrade have windows 7 drivers otherwise it's better to stay with Windows 10
