When Installing a CPU Cooler, should I do it out of the case? or inside the case. I'm not sure if it's going to interfere with anything, I have a cryorig h7 cooler, and I think installing it out of the box is easier. is that true? or should I do it inside the case, or it won't even matter
https://linustechtips.com/topic/543910-cpu-cooler-help/
i did it in my case
i have an s340 with an h7
it was pretty simple
if your mobo is already out of the pc, do it outside
but if you have a big cpu cutout, go for it
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/543910-cpu-cooler-help/#findComment-7195798
Just now, shadowbyte said:
i did it in my case
I'm planning to get the s340 alongside it as well.. it doesn't really matter right? won't block anything?
https://linustechtips.com/topic/543910-cpu-cooler-help/#findComment-7195817
what case is the important part
https://linustechtips.com/topic/543910-cpu-cooler-help/#findComment-7195825
no, it will be fine
https://linustechtips.com/topic/543910-cpu-cooler-help/#findComment-7195826
6 minutes ago, Josephdalepi said:
i thought it was an aio
then i looked it up
basically, whatever looks best to you
LOL, okay.. and it doesn't really matter does it? I think doing it outside the box is pretty much easier.. idk why, but it won't have a difference correct?
https://linustechtips.com/topic/543910-cpu-cooler-help/#findComment-7195937
it's much easier outside find
New: PCPartPicker part list
Old:Intel® Core2 Quad CPU Q8400 @ 2.66GHz, GIGABYTE GA-EP43T-UD3L, 4 GB Elixir PC3 ddr3-1333,  ASUS RADEON R7 260X, Thermaltake M9, 1TB HDD, GreatWall GW550SEL 550 WATT, BENQ GW2255, Hyper T4, Samson SR950 Headphones, fiio ek10.
https://linustechtips.com/topic/543910-cpu-cooler-help/#findComment-7195956
doesnt make a difference, but put it on outside
it makes a really good handle when putting it into the case
https://linustechtips.com/topic/543910-cpu-cooler-help/#findComment-7195962
20 minutes ago, shadowbyte said:
i did it in my case
Bro, you might have just solved my problem.
What slots did u use for the RAM on ur KRAIT mobo? I assume its in dual channel which would mean it would need to be in both the black or both the white.
Which ones did u put it in please?
Cheers.
Processor: i5-4690k @ 3.5GHz. Mobo: MSI Z97 Krait Edition. RAM: HyperX Fury 16GB @ 1866MHz Dual - Channel. Storage: WD 1TB HDD. 850 EVO 250GB. Sandisk SSD PLUS 240GB. GPU: ASUS STRIX GTX 970 DirectCU II 4GB GDDR5. PSU: EVGA Supernova 550 G2. Case: Phanteks Enthoo Pro M. Monitor: BENQ GW2270H Full HD 21.5". OS: Windows 10 Home 64 bit.
http://uk.pcpartpicker.com/p/rhnhRB
https://linustechtips.com/topic/543910-cpu-cooler-help/#findComment-7196004
IMG_20160208_164221.thumb.jpg.18b7960647the h7 has no issues with ram clearance on my mobo
you can fill up all 4 slots if you want
it doesn't matter what size the heat spreaders are
https://linustechtips.com/topic/543910-cpu-cooler-help/#findComment-7196068
