Display Settings Question
Go to solution Solved by EmeraldKiwi,
Okay I probably could have answered this with Google's help, so I did. A quick search showed me that "Windows Key + P" brings up a shortcut panel to easily manage multiple displays. Note that I only use two monitors, so I don't know how well this works on 3 or more. It works for me though. Thanks for the help anyway.
Hey so I have this thing where I play an Xbox One (ew right) a bunch and I also run my PC on dual monitors. The center monitor is the one that has to be shared between PC dual monitor setup, or when I switch input to my PC, then change my display settings on Windows 10 to "Show on only 1" to "Extend these displays". Does anyone know a way around this? Like I know I will still have to switch inputs on the monitor itself, but I don't want to have to keep changing the display settings in windows. Anyone know any shortcuts?
I'm not SAV1OUR. I promise. | Number of successfully bricked phones: 1 Samsung Galaxy S5 | 01001001 01110100 00100000 01110111 01100001 01110011 00100000 01100001 01101100 01101100 00100000 01100001 01101110 00100000 01100101 01101100 01100001 01100010 01101111 01110010 01100001 01110100 01100101 00100000 01110010 01110101 01110011 01100101 00101110
https://linustechtips.com/topic/543549-display-settings-question/
I'm not sure if I totally unederstand your issue, but I think that a monitor switch could possibly be a solution...
CPU: Intel Core i5-4460Motherboard: Asus Z97-A/USB 3.1Memory: G.Skill Ripjaws X Series 8GBStorage: A-Data Premier Pro SP900 128GBGPU: Sapphire Radeon R9 290 4GB Tri-X OC Video CardCase: Corsair SPEC-01 REDPower Supply: EVGA 600BNetworking Card: TP-Link TL-WDN4800Monitor: Asus VG248QE 144Hz 24.0" MonitorKeyboard: Razer BlackWidow Tournament Edition (Cherry MX Blue) Mouse: Logitech G100s | Quote me and say "Dope Flamingo" if you actually read this.
