So I have an XFX R7 260x and it's a great little GPU for what I need (although I'm considering an upgrade but w/e) but my only fault with it is that the fan seems to go crazy whenever I do anything, whatever the temps are. I've changed the fan curve which basically makes fuck all difference because the fan just ramps up at 100% load no matter what the temps or fan curve is.
The fan curve works up until gaming and then it just says "fuck it, let's put the fan at 50%", which is incredibly loud on this card.
See screenshot below for fan curve!
https://linustechtips.com/topic/543280-hyperactive-gpu-fan/
Uninstall MSI Afterburner. Update to Radeon Crimson...that's it...reset your MSI Afterburner too.
https://linustechtips.com/topic/543280-hyperactive-gpu-fan/#findComment-7186779
Done this, exact same result.
Does Afterburner not work on full screen mode or something because the second I press "retire to windows" the fan goes down to 15%.
https://linustechtips.com/topic/543280-hyperactive-gpu-fan/#findComment-7186831
