I've had this problem ever since i built my PC. the headphoe jack on the case wont work and sound will come through my monitor, as it has speakers. The problem here is, I want to buy some nice speakers but I just cant get the rear colored headphone jacks to work either. and that is stopping me from buying speakers. and when I do try to plug in some speakers I have, no luck. their lights turn on but no sound comes through. there is a headphone jack on my monitor, but that wont work, because I need several plug ins for the speaker to work, as my monitor only has one. Thank you for your help!
https://linustechtips.com/topic/543216-headphone-jack-not-working/
In Playback devices it will let you select which device you want to output from.
1 minute ago, Drkrinklez said:
should the back work no matter what?
If they are defaulted as the output in the playback options yes. If they don't work make sure the audio drivers for the motherboard are installed.
https://gyazo.com/72225d4472d6418d1ce2872be4a23abd
EDIT: Didn't mean to post yet >.>
Set the default audio device to your audio jack rather than your HDMI port.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
7 minutes ago, Drkrinklez said:
I have no option to enable them. it says not plugged in and it just shows that my monitors speakers are ready... this is really bothering me now! https://gyazo.com/47a5abc875de437d061794ec7542e27c
Default it to the speakers icon option on the bottom that should output through the rear jack automatically right now your going through your GPU to the monitor for sound.
erm... it wont let me. I may not know what you mean, please describe or send a pic/vid
Do you have a pair of headphone or speakers you can plug into the rear ports it should let you select the last option in that photo as the default output option. Either that try disabling the current output to then try to select the last one in he photo.
