Is there a difference?
Solved by App4that,
For a 750ti it shouldn't matter too much. If you can get a better deal on the Gigabyte by all means go for it. If you have ZOTAC in your region that's another great manufacturer.
And if you do get the Gigabyte, go for the Windforce. Worth the extra for a better cooler.
kerriya ·
Posted in Cases and Mods6 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
bill well ·
Posted in Peripherals1 -
4
2
play_circle_filled
Latest From ShortCircuit:
