Hi guys
got a 970 I'm beginning to overclock. and yes I did consider an R9 390 but it was more expensive, expensive enough to not justify the tiny performance increase.
I have gotten so far:
+125mhz CC
+400mhz MC
+10mv
sometimes (occasionally) the game I'm playing will give a grey screen and after 10-15s say that the display driver stopped working and has recovered. is this this considered a crash?
what max temps should I be looking at? 84C? just so I know what headroom I've got.
I wanted to apply an overclock of +150mhz, +600mhz MC, +50mv. what would be the maximum amount of safe voltage to give? ive seen benchmark sites state that they give +70mv??
I'm new to the masterrace as I only got this PC 3 weeks ago and I came from the PS3.
P.S OMG THE QUALITY UPGRADE IS FREAKING AMAZING. RISE OF THE TOMB RAIDER LOOKS BEAUTIFUL
https://linustechtips.com/topic/542890-overclocking-questions/
When the display driver has stopped working it crashed.
https://linustechtips.com/topic/542890-overclocking-questions/#findComment-7182843
My max temp for OCing is 75-80C  (I have never hit that high but thats my max)
try to stay there
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/542890-overclocking-questions/#findComment-7182844
1 minute ago, masked106 said:
+125mhz CC
+400mhz MC
+10mv
Try adding more voltage to this current clock and see if its stable.
Quote me if you want me to see your message. Like my post if it helped. Click "Show More" to see things that I use.
Desktop (2014): CPU: Intel Core i5 4690k @ 3.50GHz | GPU: MSi GTX 970 Gaming 4G | Motherboard: MSi Z97 Gaming 5 | RAM: 2x4GB G.Skill RipJaws X 1600MHz + 2x4GB HyperX Black 1600MHz | SSD: Samsung 750 Evo 120GB | HDD: WD Black 1TB | Cooler: Cooler Master Hyper 212x | PSU: Corsair VS650 | Case: Cooler Master Elite 431 Plus | OS: Windows 10 Home
Laptop (2017): Model: Asus UX310U
Peripherals: Monitor: Samsung S24D300 OC@75Hz + Viewsonic XG2401 (144Hz) | Mouse: Logitech G305 | Keyboard: Razer Blackwidow Chroma V2 | Headset: HyperX Cloud Core | Speakers: Logitech Z333 | Additional: Logitech G29
Mobiles: Samsung Pixon (2010-2012) | Samsung Galaxy Ace (2012-2013) | Samsung Galaxy S3 (2013-2016) | Samsung Note 4 (2015)(Lost) | Samsung Galaxy S7 (2016-2019) | Samsung Galaxy S10 (2019 - Current) | Additional: ASUS Zenwatch 2 (2016)
https://linustechtips.com/topic/542890-overclocking-questions/#findComment-7182847
90c is a safe "ceiling" for temperature on the GTX 970. Likely, you'll be able ot stay under 80c. Maxwell is stunningly good at staying cool. If your display driver is crashing, you'll want to underclock a little bit, as you might be pushing your card too far. Try +100 CC, and +375 MC?
https://linustechtips.com/topic/542890-overclocking-questions/#findComment-7182895
Graphics card overclocks crashes due to 2 reasons
1) Not enough voltage to power the current OC
2) Simply pushing the card too hard
In his case, hes saying that he only added 10mv, therefore I would suggest for him to push the voltage up to see if its able to sustain its clock.
https://linustechtips.com/topic/542890-overclocking-questions/#findComment-7182899
He asked if 84c is safe, so I refrained from suggesting further voltage. I'm not sure if those are the temperatures he's at, so I took the "better safe than sorry" approach.
https://linustechtips.com/topic/542890-overclocking-questions/#findComment-7182905
Ah I see. Didnt see the 84c. My mistake.
https://linustechtips.com/topic/542890-overclocking-questions/#findComment-7182911
I'm not getting 84C I'm getting above 75. I'm just wondering at what point should I stop Ocing.
https://linustechtips.com/topic/542890-overclocking-questions/#findComment-7182975
When it stops scaling. Maxwell doesnt scale well with volts, it scales with cold, if you were to get it under 60 You would get even better results. @Darkman@Gofspar
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
https://linustechtips.com/topic/542890-overclocking-questions/#findComment-7182979
90c is a safe ceiling. If you're comfortable, continue to bump up your voltage until you get it stable.
https://linustechtips.com/topic/542890-overclocking-questions/#findComment-7182980
try to stay there
how cute
my former 290x hit 92ºc underclocked
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
https://linustechtips.com/topic/542890-overclocking-questions/#findComment-7191905
