Hello, how are you?
I am wondering if an inverted ATX design like the new corsair 600C has any influence on GPU sagging?
Current high end GPUs sag a lot on normal cases because of the weight of those massive air cooler with lots of heatpipes and metal fins.
Usually all that weight hangs below the slot.
On an inverted ATX, the weight sits above the slot.
Would that prevent sagging in any manner?
Cheers!
https://linustechtips.com/topic/542628-inverted-atx-and-gpu/
If it worrys you, you could always grab a horizontally mounted motherboard case, corsair, Caselabs and Thermaltake make them to name a few
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/542628-inverted-atx-and-gpu/#findComment-7180242
In atx I only know the HAF XB from Coolermaster and a new case by lian li.
What are the corsair and thermaltake models?
Cheers
https://linustechtips.com/topic/542628-inverted-atx-and-gpu/#findComment-7180620
Cheers
Just checked your build log, you've dumped a lot of cash in to it, why did you go from 2x 970 to a fury x btw? less performance unless youre grabbing another x soon.
As for the cases:
http://www.thermaltake.com/products-model.aspx?id=C_00002806
http://www.thermaltake.com/products-model.aspx?id=C_00002562
http://www.caselabs-store.com/mercury-s8/
http://www.corsair.com/en-us/carbide-series-air-540-arctic-white-high-airflow-atx-cube-case
Ryzen Ram Guide
https://linustechtips.com/topic/542628-inverted-atx-and-gpu/#findComment-7181081
