Hello there,
My computer has enough free storage to backup all the files from the computers at home. I have set all the computers up so that I can access the backup drives from my home network. I have an issue though: what software should I use? I want something that just keeps a copy of the files uncompressed and updates them on a regular basis. All I could find compresses the data and I want to have access of the all the time.
Thanks in advance!
https://linustechtips.com/topic/542344-help-me-backup/
dosent Linus have one of his server doing this? look if you can find what he is doing for backup at the office because i think he has something similar to this
Builds:
https://linustechtips.com/topic/542344-help-me-backup/#findComment-7177664
running bittorent sync is an option i would believe. then having a script to copy files from the sync folder to the archive. But there may be better solutions
Everything you need to know about AMD cpus in one simple post.  Christian Member
Wii u, ps3(2 usb fat),ps4
Iphone 6 64gb and surface RT
Hp DL380 G5 with one E5345 and bunch of hot swappable hdds in raid 5 from when i got it. intend to run xen server on it
Apple Power Macintosh G5 2.0 DP (PCI-X) with notebook hdd i had lying around 4GB of ram
TOSHIBA Satellite P850 with Core i7-3610QM,8gb of ram,default 750hdd has dual screens via a external display as main and laptop display as second running windows 10
MacBookPro11,3:I7-4870HQ, 512gb ssd,16gb of memory
https://linustechtips.com/topic/542344-help-me-backup/#findComment-7177780
