HDD,PSU,GPU,Monitor,PC Case, all check now i'm on a hunt for a CPU,RAM and a mobo so i want to ask more tech savvy people what would be the best upgrade now.
I've searched for RAM and found out that i can get 16 GB DDR4 RAM for cheap so i was thinking to change to the new gen technology meaning Skylake.
I'm thinking to go with Intel i5 6500 and Ripjaws series 4 (http://www.gskill.com/en/product/f4-2133c15d-16grr) but idk if that's the best idea to go with those.
Now, i'd like to say that i'm not good with cash, meaning that i don't have much and i'm thinking to spend max 250 Euro for the CPU and Max 100 Euro on the Mobo, the money for the RAM is secured and i'm going with 16GB because i want to secure myself for the future(and i'll be needing it for Photoshop mostly and games ofc)
The things that i have right now are the GTX 960, XFX Pro Series 550W, 1TB WD HDD and the case which is a Coolermaster K350. I need recommendations for CPU,Mobo and RAM atm. Thanks in advance.
https://linustechtips.com/topic/542295-slowly-building-up/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (€244.93 @ Mindfactory)
Motherboard: MSI Z170A PC MATE ATX LGA1151 Motherboard  (€117.41 @ Mindfactory)
Total: €362.34
Generated by PCPartPicker 2016-02-06 14:57 CET+0100
https://linustechtips.com/topic/542295-slowly-building-up/#findComment-7177131
Total: €362.34
I'd rather not go with OC build because it voids the warranty and i would need to educate myself on how to maintain it and how to overclock. I'll reconsider that but my biggest reason why i won't/can't OC is time which i don't have much nowadays. Thanks for the recommendation.
https://linustechtips.com/topic/542295-slowly-building-up/#findComment-7177155
It's still faster than the 6500 without overclocking it turbos to 3.9GHz and the 6500 to 3.6GHz
https://linustechtips.com/topic/542295-slowly-building-up/#findComment-7177160
Total: €362.34
you'll need a cooler too. 6600k doesn't come with one
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/542295-slowly-building-up/#findComment-7177195
Well he said the budget was only for a mobo + cpu but add 25€ to that and get a 212 evo
https://linustechtips.com/topic/542295-slowly-building-up/#findComment-7177198
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($204.99 @ Newegg)
CPU Cooler: be quiet! SHADOW ROCK LP 51.4 CFM CPU Cooler  ($39.90 @ Newegg)
Motherboard: Gigabyte GA-H170-GAMING 3 ATX LGA1151 Motherboard  ($104.99 @ Newegg)
Total: $334.88
Generated by PCPartPicker 2016-02-06 09:17 EST-0500
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/542295-slowly-building-up/#findComment-7177212
Yeah but is it efficient? I don't need anymore power if a 6500 is enough for gaming.
I didn't meant to spend more money than that. Not at the moment at least if its not needed, maybe later like an SSD.
Total: $334.88
Is the CPU Cooler needed? I thought CPUs come with stock coolers?
https://linustechtips.com/topic/542295-slowly-building-up/#findComment-7178455
Skylake at least skylake K cpu's won't come with a stock cooler.
https://linustechtips.com/topic/542295-slowly-building-up/#findComment-7178490
not needed when going with this particular cpu but I like quiet and cool operation and this is what an aftermarket solution offers. So it's up to you whether you stick with the stock one or go for a more quiet and cooler solution
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/542295-slowly-building-up/#findComment-7179114
I see, i'm trying to get the PC parts right now and about those things i'll think some other time. Thanks
https://linustechtips.com/topic/542295-slowly-building-up/#findComment-7183068
