Hi this is my code and I was trying to make it so that it asks for the gender, for some reason it just skips the question and goes straight to the calculation. Any suggestions? Thanks for the help in advance.
import java.util.Scanner;
public class BMR
    public static void main(String[] args)
        Scanner keyboard = new Scanner(System.in);
        double Height;
        double Weight;
        int Age;
        System.out.println("Hello, please allow me some information so that I can figure out how much chocolate bars you would need to eat to keep weight.");
        System.out.println("Height in inches:");
        Height = keyboard.nextDouble();
        System.out.println("Weight in pounds:");
        Weight = keyboard.nextDouble();
        System.out.println("Age:");
        Age = keyboard.nextInt();
        System.out.println("Male or Female");
        String Gender;
        Gender = keyboard.next();
        double Cocobars;
        double BMRMale;
        if (Gender.equals("male")){
            BMRMale = 66 + (6.23 * Weight) + (12.7 * Height) - (6.8 * Age);
            Cocobars = (BMRMale / 230);
            System.out.println("Your BMR is "+BMRMale+" calories so you would need to eat "+Cocobars+" chocolate bars.");
        }else{
            double BMRFemale;
            BMRFemale = 655 + ( 4.35 * Weight ) + (4.7 * Height ) - (4.7 * Age );
            Cocobars = (BMRFemale / 230);
            System.out.println("Your BMR is "+BMRFemale+" calories so you would need to eat "+Cocobars+" chocolate bars.");
https://linustechtips.com/topic/541325-java-help/
Seems like it should work.
BUt whats with the lack of methods???
https://linustechtips.com/topic/541325-java-help/#findComment-7167560
Just now, Sebastian Kurpiel said:
? Please explain, it just skips the male and female part and goes straight to the BMR part.
does it ask for age, weight, and all that stuff?
https://linustechtips.com/topic/541325-java-help/#findComment-7167579
Yes it ask for each but skips the gender part.
Odd, it seems like it shouldent.
That said, I see a bunch of other problems with your code, not problems that would stop it from working, but problems.
  • Lack of driver/different classes
  • Lack of methods
  • user must input male exactly, otherwise the program will think they are female. If they write Male or Man or something, it will think they are female
  • Variables are declared halfway through the code
https://linustechtips.com/topic/541325-java-help/#findComment-7167603
  • Lack of methods
Oh, what do you mean by lack of methods?
https://linustechtips.com/topic/541325-java-help/#findComment-7167614
How much programing experience do you have?
https://linustechtips.com/topic/541325-java-help/#findComment-7167621
We have brought up methods in class before, this my 3rd week in the course. Got it to work, thank you :)
What did you have to do?
It looked fine to Me.
https://linustechtips.com/topic/541325-java-help/#findComment-7167657
Yeah it just ran normally this time.. For checking if a number is odd I would just make sure I could divide it by 2 and it doesn't leave decimals correct?
Also when you said declare variables, do you mean at the beginning?
https://linustechtips.com/topic/541325-java-help/#findComment-7167702
7 minutes ago, Sebastian Kurpiel said:
Also is there a simple way to round to 2 decimals?
No
https://linustechtips.com/topic/541325-java-help/#findComment-7167856
If(num%2==0)
Num is even
Else
Num is odd
https://linustechtips.com/topic/541325-java-help/#findComment-7167862
2 minutes ago, elpiop said:
multiply the number by 100, then round it using Math.round, and then divide it by 100.
or you can use DecimalFormat, which would be pretty easy also.
Could you write the code for that?
21 minutes ago, spwath said:
If(num%2==0)
Num is even
Else
Num is odd
Thank you, you are the man my friend.
https://linustechtips.com/topic/541325-java-help/#findComment-7167987
57 minutes ago, Sebastian Kurpiel said:
Sorry, how would add that to code? Like would I add it to the beginning?
That code snippet will simply take a number which is in a variable, round it, and put it in another variable.
Therefore, you can add that code wherever you want, as long as the number to round is in a variable.
For example:
Cocobars = Math.round(Cocobars * 100) / 100;
Now the Cocobars number is rounded to two decimal places.
https://linustechtips.com/topic/541325-java-help/#findComment-7168361
For example:
thank you :) my code looks more simple now.
https://linustechtips.com/topic/541325-java-help/#findComment-7170578
  • 5 months later...
