yep, I'd add at least a 240 to the loop, other than that, I might switch out your serial waterloop config on the GPUs to a parallel config. other than that, maybe go hardline in you're into that sort of thing. Either way, it'll be a damn nice PC.
¢υѕтσм ℓσσρ σя ησтнιηg αт αℓℓ
https://linustechtips.com/topic/541265-dual-gpu-water-cooling/#findComment-7166956
8 minutes ago, Shmuel_1 said:
I was planning to build a PC with custom water cooling loops. Here are all the parts (Include water cooling equipment)
I had a loop panned and i was hoping that it would work
Loop
Please leave feedback here.
5 minutes ago, AcidzDesigns said:
I would add another 240mm rad in the front to help the cards
Other then needing another Rad that should be fine.  You could get away with a 360 but I wouldn't suggest overclocking.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/541265-dual-gpu-water-cooling/#findComment-7166965
i'd add another rad to that loop for the Graphics cards, cause like this your CPU's gonna solid fine but for thouse GPUs specially the second one, not so much
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/541265-dual-gpu-water-cooling/#findComment-7166994
https://linustechtips.com/topic/541265-dual-gpu-water-cooling/#findComment-7167055
that would allow for some overclocking, dependant upon the CPU. I run a 4790K and a 980Ti with a 360 & 240 Radiator and the GPU stays below 65C. The CPU gets hot (85), but that's because I'm using a pretty shit waterblock for like 2007. Water temps never top 40C
https://linustechtips.com/topic/541265-dual-gpu-water-cooling/#findComment-7167072
11 minutes ago, Shmuel_1 said:
So would this allow for a mild overclock?
56b3d9b200214_loop2.thumb.png.6f7d8e7031
Drop that front drive bay out, and use 2x 360mm. I use a 360 for my 970s and then a 360+240 for my CPU (240 aint required but I have space). That should give you plenty of head room and allow you to have fans on medium speeds. As others have said go parallel or grab a parallel bridge from ek. Don't forget to add a drain at the lowest point
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/541265-dual-gpu-water-cooling/#findComment-7167075
