So i recently installed Linux Ubuntu on my computer where i previously had Windows 10. I have 2 monitors connected with my computer, one is connected to my Nvidia gpu and the other is connected to my motherboard's dsub port. On windows this wasn't a problem it worked flawlessly. Now on Ubuntu the screen plugged into the Nvidia GPU works fine but the second screen is showing only black with a single white stripe on the top left corner of the screen.
I'm fairly new to Linux so I'm not sure what i should do? I've tried detecting the other display in the settings menu as well as nvidia control panel. It's not being detected. But the screen is showing the white cursor.
https://linustechtips.com/topic/541100-dual-monitors-problem-gpu-igp/
You will not be able to run two monitors off of two different GPUs in Ubuntu.  If your Nvidia GPU has more than one output you can run dual monitors driven by one GPU.  Likewise, if your motherboard has two outputs you can run dual monitors that way.
XWindows has no way of dealing with that good to know...
Everything you need to know about AMD cpus in one simple post.  Christian Member
Wii u, ps3(2 usb fat),ps4
Iphone 6 64gb and surface RT
Hp DL380 G5 with one E5345 and bunch of hot swappable hdds in raid 5 from when i got it. intend to run xen server on it
Apple Power Macintosh G5 2.0 DP (PCI-X) with notebook hdd i had lying around 4GB of ram
TOSHIBA Satellite P850 with Core i7-3610QM,8gb of ram,default 750hdd has dual screens via a external display as main and laptop display as second running windows 10
MacBookPro11,3:I7-4870HQ, 512gb ssd,16gb of memory
