Power supply help
Go to solution Solved by alexhelvetica,
You can use a higher wattage PSU than what you need, the only downside is that it is less efficient.
It would work perfectly fine, the wattage of a PSU is the max. wattage that the PSU can deal with, but based on it's efficiency it can only deliver a bit less. (if your components drain less than this wattage-efficiency than its fine, 500W PSU will give your components the demanded power but have to cosume a bit extra power cause of his efficiency)
But I think you should atleast inform youself a bit about PSUs befor you ask someone. Simple google search should give you enough infomations. (don't want to sound pissed or something)
https://linustechtips.com/topic/540920-power-supply-help/#findComment-7163156
Your efficiency explanation is kinda off. I'd check the Efficiency guide pinned on this subforum :)
3 hours ago, jayarishi said:
hi i want to know what would happen if i put a 500w psu into a 300w machine
is it too much for it to handle or can it manage?
is the power distributed perfectly or do i need specific ones??
thanks
A 750W will just deliver whatever amount of power is asked of it up to 750W
https://linustechtips.com/topic/540920-power-supply-help/#findComment-7163977
Ah ... OK you're right Sir, than I miss understood the labling of PSU's for years ^^
https://linustechtips.com/topic/540920-power-supply-help/#findComment-7164179
