1 minute ago, Rev:) said:
I currently own a razer naga 2014 and i am wondering if i should upgrade to a Logitechg502 spectrum. I have the naga because i was young and thought it looked cool  even though i am not a mmo gamer.
If ya don't need it, don't get it.
PC Specs:
Core I5 4690K CPU
Gigabyte GTX 960 windforce 4GB GDDR5 GPU
Corsair 100R case
Seasonic 620W S12-II PSU
Kingston SSDNow 120GB SSD
Toshiba 1TB HDD
Asrock H97 Pro4 motherboard
8GB panram DDR3 1600 RAM
Windows 10 home 64 bit
https://linustechtips.com/topic/540372-mouse-help-please/#findComment-7156945
never liked g502. razer deathadder is a good mouse.. good sensor and omrons
also zowie... love them
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/540372-mouse-help-please/#findComment-7156966
i dont like the glossy buttons on the g502, if youre having sweaty hands from time to time it feels nasty. i prefer matte finish on everything. im currently using a asus gladius, its a great mouse. the less buttons/features the better. just the sensor matters imho
IF YOU WANT ME TO REPLY TO YOU, QUOTE MY POST.
Fire Strike Score
5820K @ 4.8GHZ - 1.25v / Uncore @ 4.5GHZ - 1.2v / 3000MHZ G.skill 32GB Quad Channel / Asus Rampage V Extreme / 950 Pro Nvme / Sound Blaster ZxR  / 980 TI / Windows 7
https://linustechtips.com/topic/540372-mouse-help-please/#findComment-7156984
G502 Proteus Spectrum is quite a nice choice imo. I have the G502 Proteus Core, really satisfied with it.
Other mice you can choose: Razer DeathAdder Chroma, Mionix Castor (I doubt that you can get this, at all), Roccat Kone Pure Military (all are right-handed ergonomic)
https://linustechtips.com/topic/540372-mouse-help-please/#findComment-7156993
14 minutes ago, JoeyDM said:
Summoning @Pandalf
*zap*
Summoning successful!
@Rev:) If you are satisfied with the performance of your Naga 2014, it's not broken and you find it comfortable to use then there's no reason to buy a new mouse. Otherwise I'd suggest going to a store and trying some mice, because it's hard to receive a proper suggestion.
The G502 has great features, but it's pretty heavy for most people who play games with low sensitivity and flick their mouse a lot. Some people with large hands might also find it uncomfortable, because it's pretty narrow. As I said, I strongly suggest trying before buying. If you are playing FPS games on a high or competitive level, this is usually not a good mouse.
Watch this video to get some knowledge and know what to look for when buying a mouse, so you don't end up making a blind purchase:
You can answer the questions from the video here so we can give you a proper suggestion if you decide to change your Naga. :)
From salty to bath salty in 2.9 seconds
https://linustechtips.com/topic/540372-mouse-help-please/#findComment-7157048
Just now, NationsAnarchy said:
I really enjoyed the video, extremely detailed and informative, pardon me but is that your own video ? :D
It's a channel I recently stumbled upon and that guy makes the most detailed and informative mouse reviews. I keep spamming this video on almost every "mouse suggestion" thread because it's the only one I've come across that explains properly what to look for when buying a new mouse. I was doing a questionnaire a while ago, but now I'm too lazy for that. :D
https://linustechtips.com/topic/540372-mouse-help-please/#findComment-7157084
Oh lol I just see that you're from Bulgaria and the guy on the video has a strong British accent (turned out he's Australian lol, oh well my ears suck badly)
I might use the video for recommendation/guidelines to others as well, thanks to you :D
Edited by NationsAnarchy
OMG
https://linustechtips.com/topic/540372-mouse-help-please/#findComment-7157093
