So this is a tricky one, every once in a while my system will shut off. Not just windows entering the shutdown mode and waiting a while to completely shut down, I mean total shutdown in a second. I couldn't figure out how  this was happening and i thought it happened once my CPU maxed out its performance because it only happens when in game. Help is much appreciated, thanks in advance
https://linustechtips.com/topic/539113-random-power-failure/
1 minute ago, Ninjabossman10 said:
CPU: FX-6300 (non OC'd)
GPU: R9 380
PSU: Some coolmax one. sorry i dont know the name
What's the wattage of the PSU?
The R9 300 series cards use a lot of power in the high-end cards. You probably need at least a 650w to feed that card and CPU.
https://linustechtips.com/topic/539113-random-power-failure/#findComment-7143412
not sure about that
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/539113-random-power-failure/#findComment-7143435
I'm going to assume that overdraw protection on the PSU kicks in and kills the system. Either that or your VRMs are overheating and overheat protection kicks in and shuts it down.
Could you be more specific? What motherboard do you have? Also, could you post the label from your PSU here?
https://linustechtips.com/topic/539113-random-power-failure/#findComment-7143449
Just now, Patrick Bateman said:
not sure about that
R9 380 consumes about 300w at load http://www.anandtech.com/show/9784/the-amd-radeon-r9-380x-review/13
FX-6300 is about 230w at load http://www.tomshardware.com/answers/id-1729936/amd-6300-power-consumption.html
So if your 650w PSU was even 85% efficient you would only have roughly 560w to work with. Leaving 30w or so for peripherals, fans, consumption spikes, etc.
https://linustechtips.com/topic/539113-random-power-failure/#findComment-7143465
85 percent efficiency does not mean your psu can only deliver 560w..
https://linustechtips.com/topic/539113-random-power-failure/#findComment-7143561
