Posted February 1, 2016 How do I limit like as in limit the speed on a specific mac address or something like that? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 QoS(Quality of Service) is a feature that enable you to provide different priority to different computers. A lot of higher end modern routers support this feature, but lower ends might not or their implementation of it might be poor. Did my post help you? Then make sure to rate it! Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 2, 2016 All depends on the Router, We use Zyxel products at work and for our customers and enable BMW (Band width Management). Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2016 +1 What router do you have? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 6, 2016 Author I have a Linksys router Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 6, 2016 When someone asks what router you have, they mean model number. Linksys makes thousands of different devices. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 9, 2016 Author On 06/02/2016 at 10:44 PM, Trikein said: When someone asks what router you have, they mean model number. Linksys makes thousands of different devices. Sorrry for the little info here's the model wrt54gs ver 6 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 9, 2016 That router is too old to have proper speed QoS. It only has latency QoS. Your only option would be a new router or 3rd party firmware. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 14, 2016 Author If i change my router is it going to be good? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 14, 2016 If you buy one that supports the features you want, yes. Network/Homelab build log Main PC: "Aqua Blue" Server: 15TB+ "Blue Lightning" 3900x, 32GB RAM @3200mhz, RTX 3090, 2.5TB+ SSD Storage, 4x2560x1440 monitors Samsung Galaxy Z Fold2 5G, +2x Note 9 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 15, 2016 If you have something that can make a guest wifi you can go into the routers settings through your browser then you can make a guest wifi and limit it's bandwidth. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
