Need help
Go to solution Solved by Trikein,
Need a bit more info on the issue. What are you using the ethernet to connect the PC to? A router? A modem? If you are connecting a new PC to a stand alone modem, which would only have 1 ethernet on the back, then you need to reboot the modem for the PC to get a IP.
If you are connecting to a router, are you getting a IP? Windows Key + R > CMD > Ipconfig. There will be a bunch of stuff, but what you are looking for will look something like this:
Windows IP Configuration
Ethernet adapter Local Area Connection 2:
   Connection-specific DNS Suffix  . :
   IPv4 Address. . . . . . . . . . . : 192.168.1.136
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 192.168.1.1
PS. You said you tried with a new cable in the living room. How do you have a ethernet connection in your room and the living room? Do you have ethernet jacks in every room? If so, what connects them all together?
I have just completed my first computer build everything went ok but when I plug in the Ethernet cable I have no internet I went out to my living room and try with a new cable still nothing I can't think of anything or what to do so I really hope some of you people can help thanks
https://linustechtips.com/topic/538761-need-help/
https://linustechtips.com/topic/538761-need-help/#findComment-7139731
5 minutes ago, Trikein said:
What model motherboard do you have? I assume you don't have a separate NIC?
I'm using a asus z170 maximum hero mobo
well my main router is in the living room and I have one of the wallplug thing that use the wall wire as cable and provide Internet I my room and as a spare Nic I don't have one still don't know much as I sad that's my first build
https://linustechtips.com/topic/538761-need-help/#findComment-7139749
Here is a link for all the drivers: https://www.asus.com/au/Motherboards/MAXIMUS-VIII-HERO/HelpDesk_Download/
CPU: Intel Core i7 4770 @ 3.4 ghz (Turbo 3.9ghz) RAM: Trancsend 2x 8gb 1600mhz DDR3 (16GB) GPU: Gigabyte Nvidia Geforce GTX 970 Case: Cooler Master HAF922 Storage: Sandisk Ultra II 120GB Solid State Drive, Seagate Barracuda 1TB Hard Drive PSU: Cooler Master CX750 750w Power Supply.
Keyboard: Logitech G310 Mechanical Compact Keyboard Mouse: Logitech G302 Gaming Mouse Displays: 3 Monitors Operating System: Windows 10 Home
https://linustechtips.com/topic/538761-need-help/#findComment-7139771
Go on the ASUS website and download the drivers if you have not already done that. Are you running Windows 10?
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/538761-need-help/#findComment-7139774
The Asus Z170 looks to use Intel® Ethernet (i-219V). What OS are you using? If Windows 10 64bit, then you can find the driver here. If you use a different OS, see the link by mclarence.
Yes, download the driver onto a USB.  Then insert the USB into the PC and go to: Windows Key + R > devmgmt.msc > Network Adapters > Should see a little yellow ! next to the adapter missing a driver. Double click on it then go to Driver tab and click update driver and browse for the file on the USB.
https://linustechtips.com/topic/538761-need-help/#findComment-7139786
2 minutes ago, _BJE_ said:
Yea I'm running Windows 10 do I install the driver on a usb? If not how?
Just download the driver onto a USB stick from another PC. Surprisingly, W10 should install a generic driver and then download the proper one.
https://linustechtips.com/topic/538761-need-help/#findComment-7139794
