hyper tx3 for overclocking?
the 212 evo would be better.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
4 minutes ago, froot said:
cpu is fx-6300
will this cooler overclock or should i get the hyper 212 evo?
You can overclock on that cooler(I have with a fx6100), but a 212 evo will be better. I would see what you can do on the TX3 first, then decide on a better cooler once you reach a max.
Just to alert you:
The CRYORIG H7 Would also serve you just as well as the 212 evo, but is a little shorter and looks differently if that's your thing.  (costs similarly too.)
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
2 minutes ago, Weak1ings said:
Just to alert you:
That cooler looks nice but i don't think its available in Canada.
