Hey everyone, i would just like some ideas on good gaming monitors. I am looking for a 24-25 inch screen, 144hz, g sync, 1ms response time and something that is able to use a vesa mount for the future when i do eventually wall mount them, and something that is not too crazy in price so maybe less than $500 give or take.
Thank you heaps in advance! :)
https://linustechtips.com/topic/538512-help-on-monitors-please/
this one:
http://pcpartpicker.com/part/asus-monitor-vg248qe
you don't want gsync or freesync?
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137391
3 minutes ago, PrettyBoy said:
Oh yeah and what are your thoughts on widescreen for gaming?
depend what games you play, not all games support it and some games are just stretched out to some extent to fill the screen...might get better support in the future or maybe not...99.9% of the people are gaming on 16:9 resolutions so obviously 21:9 take the backseat in developers mind...also it's not great for shooters since it mess with your aim a bit but you can get used to it. If you play a lot of racing/sim games it can be pretty good. But 144hz 21:9 will cost you a pretty penny...this is your cheapest option:
http://pcpartpicker.com/part/benq-monitor-xr3501
so you'd have to go with a 60hz monitor if you go ultra wide...up to you to see if it's worth it for you. :)
This monitor i linked...i wouldnt spend 1000$ on a 1080p TN monitor...it just does not make sense.
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137537
Yeah i get what you mean, so the monitor you recommended would be good for gaming? And what are your thoughts on the monitor you are personally using yourself?
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137548
no i'm not but it's one of the most commonly used panel among gamers and it's very good the reviews for it are very good and it's priced well that's why i suggested it you can't go wrong.
If you want to stick to 1080p, and you do not want Gsync....but you want 144hz then IMHO this is the perfect monitor for you.
You can't get IPS panels that are doing 144hz at 1080p so this is the next best thing.
You have to understand, 1080p is kinda ''yesterday'' if you want a gaming monitor with 144hz and an IPS panel you have to go to 1440p which is more GPU demanding but it does look a lot better. (GTX 970/780ti or R9 290X/390 GPU minimum IMHO)
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137563
What i'm saving for is the gtx 980ti, which is why i wanted a like decent monitor that is 144hz, g sync and a 1 ms response time.
The first monitor i was looking was https://www.pccasegear.com/products/31962/acer-predator-xb240h-24in-144hz-g-sync-gaming-monitor but i wanted to see what other people would have recommended as this will be my first pc build.
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137654
maybe you'll get more recommendation later...this acer monitor is also quite good but it's pretty much the same as the Asus one i linked but in a different casing...but it has Gsync so it's quite a bit more expensive.
Also, GTX 980ti is quite a bit overkill for 1080p IMHO...you should wait for next gen pascal based GPU's and grab a mid range card which should perform quite well and cost you around 450$ or something like that.
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137680
What about a monitor that would be around 1440p?
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137706
16:9 WS gaming has been around for ages, I think the new trend is Ultra Wide gaming which is 21:9 aspect ratio. I'd recently gotten a 29" 2560x1080 AOC UW monitor to try out on my FX8350/2x HD7950 rig and I can honestly say I'm pleased with what I see and the performance I get. Most games work flawlessly at 21:9, though like EyeFinity, the figures on the sides of the screen do appear a little stretched, while those figures and such at the center of the screen are just fine. Like EyeFinity (I do have an EF setup with triple 24" monitors on my main rig), I find 21:9 gaming to be more immersive since there's more screen real estate available to me.
Below is a list of Gsync monitors available at newegg, having tried out UW 21:9 gaming, my personal fave would be the Asus Predator X34.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=gsync+monitors&N=-1&isNodeId=1
I've heard read that Samsung and LG IIRC (and one more monitor brand that I can't for the life of me recall), will be making even bigger screen UW monitors later on in the year......can't wait for them to hit the shelves, then I'd wait a little longer for prices to get a little more real before buying!
Below is another reason why I'm dead set on 21:9 monitors from now on....no more black bars on top and below like on 16:9 monitors.
Edited by GamerDude
Insertion of picture
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137708
would be something like this one which is 2560x1440 with 144hz but no Gsync...450$ or so:
http://pcpartpicker.com/part/asus-monitor-mg278q
that would be worth it if you have plans to buy a powerful graphics card (GTX 980/780ti or R9 390/390X for example) ideally a GTX 980ti or next gen equivalent performing GPU.
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137718
I do not think i will be going any higher than 25 inch because of desk space, from my planning i am able to fit my pc and maybe two 25 inch monitors max.
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137747
But will not having G sync play a large part in possible screen tearing?
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137760
Why not one big monitor then? Like the Asus Predator X34?
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137765
Because i am planning to have the second monitor hooked up to my Xbox, so it will switch between PC and Xbox through a HDMI Splitter, and the first monitor for pc gaming sort of thing.
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137769
you can have both your Xbox and your PC hooked to the same monitor and switch from one to the other too.
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137779
Yeah but if i want to be able to watch something on the other monitor or something.
But do you feel it would be better to get a 27 inch monitor?
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137787
Ahhh, OK, that cleared it up. Hmmmm, then get one of those 24" monitor in the list, you can spend more on the one for your PC since you want Gsync and such, and buy a relatively cheap one for your Xbox......they don't necessarily have to be the same, as long as the size are.
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137792
Ahhh, OK, that cleared it up. Hmmmm, then get one of those 24" monitor in the list, you can spend more on the one for your PC since you want Gsync and such, and buy a relatively cheap one for your Xbox......they don't necessarily have to be the same, as long as the size is.
Double post! Damn, I goofed......$%#@ new forum format takes some getting used to.
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137798
6 minutes ago, PrettyBoy said:
Why is that >1k USD (I assume it's in USD) when the very same model at newegg is <700USD?
http://www.newegg.com/Product/Product.aspx?Item=9SIA1N82KJ1053&cm_re=gsync_monitors-_-24-236-405-_-Product
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137852
Because i am in Aus its the Australian price, can be a pain trying to work out if Aud or Usd aha.
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137868
Dangit, though I'm not from the US myself, I usually assume everyone else is. Anyway, for that price, I think it's reasonable since it's pretty near the US price for it. Now, IF I were to buy one here locally, it'd cost me a damn sight more than even 1200 (AUD is almost parity with local currency in my neck of the woods).
https://linustechtips.com/topic/538512-help-on-monitors-please/#findComment-7137959
