Have you tried formatting it in another format, like FAT32? thats what my drive is formatted to and i can read and write to it no proble, you can do so by right clicking on the drive, click properties and you should find a format tab and select FAT32 instead of NTSF
12 minutes ago, Giuseppe96 said:
Ok I have a question: I can't have acces to my usb drive (kingston 8GB) because is "locked" in read only mode... I've tried many things but i can't solve this problem... Anyone could help me?
The volume is formatted in NTFS partition with windows.
When all spare blockes are used up the drive goes in read only mode to pretect data. but this usually only happens with very old, super cheap or permanently used usb drives.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
