Cpu temps with Civ 5
Solved by givegomezthegun,
70's are considered ok, they are higher than I personally like to see.
Might sound like a stupid question, but is your heat sink clean? If it's been a while since you cleaned it out, dust build up will harm cooling performance. Depending how old the thermal paste is and what type, that could affect it as well.
That being said.. most strategy games are really cpu intensive, if you're not seeing temps like that in anything else I wouldn't worry too much.
