I have a thin power cord for my monitor and a thick one for my pc. I wanted to know if its ok to use the thin cord on my pc, and the thick one on my monitor for only from friday at night to sunday until say 4pm.
Thanks for the help!!!!
I7-6700k, Asus Maximus VIII Formula, 2 x 8GB Corsair Dominator Plantinum ram, ASUS GTX 960 STRIX, sound blaster zx, 1TB boot drive ssd, 128GB/256GB storage ssd, 1TB storage HDD, 4TB of storage (backup),Windows 10 Pro,1000w psu
https://linustechtips.com/topic/537454-will-using-this-be-ok-for-my-pc/
It might not be able to provide enough power for the system but I'm not too knowledgeable with this so thats just my 2 cents
If they both have the same connectors they might work. I believe they're standard. Do you have a picture?
  • CPU i7 4790k - 4.5 Ghz | Motherboard Asus Z97-E/USB3.1 | RAM G.Skill Ripjaws X Series 16GB (2 x 8GB) | GPU MSI GTX 980 GAMING 4G - 1520 core/1811 memory | Case Corsair SPEC-03 Red | Storage Sandisk Ultra II 480GB | PSU Enermax 650W 80+ Bronze | Display LG 22MC57HQ-P | Cooling Cooler Master Hyper 212 EVO
Here are the pictures.
post-7350-0-69273000-1454119126_thumb.jp
Generally it's fine, however those power cords usually have a rating on them which would provide a more exacting answer. It honestly depends on your systems power draw, which is likely considerably less than the rating for the cord.
This begs the question of why do you need to switch the cords?
