My rig has a 3930kj, 16gb corsair dominator platinum, and direct CU2 780. I'm not getting any post, and no debug LED either. Any ideas what to do?
For all the falsely accused: message me and we can decide how to right all the wrongs that happened to you!
I'm looking at the major corporations, the lying online communities, the government that protects us...
We are HUMANS, not robotic slaves!
https://linustechtips.com/topic/53646-no-debug-led-on-rive/
Do you have all the connectors running? Do you have sufficient power?
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/53646-no-debug-led-on-rive/#findComment-720161
Does it even get power?
yeah, everything is running besidies the led.
https://linustechtips.com/topic/53646-no-debug-led-on-rive/#findComment-720170
It can run even with low power. What is the wattage for your PSU?
https://linustechtips.com/topic/53646-no-debug-led-on-rive/#findComment-720179
1600
https://linustechtips.com/topic/53646-no-debug-led-on-rive/#findComment-720182
Well no debug LED makes it sound like a motherboard issue to me then, otherwise it should be able to diagnose what was wrong. :(
Hmm, everything else seems to work; it just won't post -__-. Maybe I didn't put the CPU in well enough? You think that could be the case?
https://linustechtips.com/topic/53646-no-debug-led-on-rive/#findComment-720218
