No signal - HELP! :(
Go to solution Solved by CommanderAlex,
Install Windows and download the GPU drivers before putting the GPU back in. My build wouldn't boot when I put my 1st build together and I removed the GPUs and it started right up.
Hi! I bought my new PC and received it one day ago. I gathered the pieces and built it. When I turned my computer on, it was shown on my television ''No Signal''. Any suggestions?
New PC build:
Case: Fractal Design Core 1000 FD-CA-CORE-1000-USB3-BL Black Steel MicroATX Mid Tower Computer Case
Motherboard:MSI H81M-P33 LGA 1150 Intel H81 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
GPU: EVGA 02G-P4-3753-KR G-SYNC Support GeForce GTX 750 Ti Superclocked 2GB 128-Bit GDDR5 PCI Express 3.0 Video Card
Power Supply: Thermaltake TR2 W0070 430W ATX12V v2.3 Power Supply
CPU: Intel Core i5-4590 Haswell Quad-Core 3.3 GHz LGA 1150 84W BX80646I54590 Desktop Processor Intel HD Graphics 4600
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
SSD: Kingston SSDNow V300 Series 2.5" 120GB SATA III Internal Solid State Drive (SSD) SV300S37A/120G
HDD: Seagate Desktop HDD ST1000DM003 1TB 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
DVD: ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS
https://linustechtips.com/topic/536072-no-signal-help/
New PC build:
Case:
Motherboard:
GPU:
Power Supply:
CPU:
RAM:
SSD:
HDD:
DVD:
plugged in right?
https://linustechtips.com/topic/536072-no-signal-help/#findComment-7110921
Is there a switch on the back of the PSU? Make sure it shows (-) and not (O). Did you use the heatsink with the CPU or some aftermarket cooler?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/536072-no-signal-help/#findComment-7110932
I tried with a monitor, but unfortunately, it still displays no signal.
I also tried to change my GPU and the result was the same ''no signal''.
is on the right cable in the settings? like a tv plugged into hdmi 1 says no single on hdmi2 but when you switch it to hdmi 1 it works
https://linustechtips.com/topic/536072-no-signal-help/#findComment-7110958
Did you try to start the computer without the GPU? Plug your Tv/monitor into the motherboard with a DVI or what your using.
https://linustechtips.com/topic/536072-no-signal-help/#findComment-7110968
Oh, now it works.
It says:"CPU or Memory changed !!! Please enter Setup to configure your system. Press F1 to run setup. Press F2 to load default values and continue"
https://linustechtips.com/topic/536072-no-signal-help/#findComment-7111006
https://linustechtips.com/topic/536072-no-signal-help/#findComment-7111011
https://linustechtips.com/topic/536072-no-signal-help/#findComment-7111039
Thanks, glad we got your system running.
https://linustechtips.com/topic/536072-no-signal-help/#findComment-7112002
