All the jacks work and come up. Its just no output. I tried with headphones on the same jack too .
Go to the speaker icon on that little popup menu next to where the clock and calendar is.  Look for the speaker Icon, right click it.  Press playback devices and make sure you have your playback device set to default.
  "As Individuals we are weak like twigs but when we come together we become a mighty faggot"
https://linustechtips.com/topic/535758-no-sound-playing/#findComment-7107300
This does not make any sense, what are you trying to say?
As is, it 'says' everything works it's just that it doesn't work.
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
https://linustechtips.com/topic/535758-no-sound-playing/#findComment-7107313
