Little weird problems - Rename folder error
Go to solution Solved by alexhelvetica,
Rename it to "Nisekoi [season 1-2" and then rename it back to "Nisekoi [season 1-2]"
I tried to rename " D:\Videos\ Nisekoi [season 1-2]" to "D:\Videos\Nisekoi [season 1-2]" without a space next "N", then I got a rename folder error. And I didn't see same name as other folders.   My OS is Windows 7 Home 64 Bit, and I have 2 WD Black HDDs. I got everything closed down, and still got a error. Did I missing something important?
CPU:AMD Ryzen 5 5600 3.5 GHz Processor | CPU Air Cooler:Thermalright Assassin X 120 Refined SE | Motherboard:MSI B450M GAMING PLUS MATX AM4
Memory:G.Skill Ripjaws V Series 32GB (2x16GB)  DDR4-3200 | GPU:PowerColor Fighter Radeon RX 7600 8 GB Video Card
Storage #1:Silicon Power A55 512GB SSD (OS driver) | Storage #2: Silicon Power A60 1TB M.2-2280 PCIe 3.0 X4 NVMe (Anything else)
Case:Cooler Master MasterBox Q300L | Case Fan: 3x Thermalright TL-C12C (2x intake fans, 1x exhaust fan)
Power Supply:Corsair CXM (2015) 450W Bronze 80 Plus |OS:MS Windows10 (64-bit) | Monitor: ASUS VG275 27” 1080p 75 Hz FreeSync
https://linustechtips.com/topic/535533-little-weird-problems-rename-folder-error/
My bet is because windows includes "filters" to take out what it believes are accidental spaces surrounding names, it is thinking those are the same before & after and not letting you change it.  You'll notice this same problem trying to rename something from "abc" to "ABC" if you are using NTFS from Linux, since NTFS stores case, but is not actually case-sensitive, so without windows' workaround to let that happen in one step, it considers it the same name and fails :D
I feeling idiot! *tableface* Thanks anyway.... :D
