I'm helping a friend choose parts for a build and figured it would be a good Idea to get more opinions. This build is really only going to be used for gaming.
CPU: i5-3570k
Cooler: Cooler Master Hyper 212 evo
RAM: Corsair Vengeance 8GB(2 x 4) DDR3-1600
Motherboard: ASRock Extreme4 ATX
Hard Drive: Western Digital Caviar Blue 1TB
SSD: Samsung 830 128GB
Graphics Card: Gigabyte Geforce GTX 670 2GB
Case: NZXT Switch 810
PSU: OCZ ModXStream Pro 500W 80 PLUS Certified
OS: Windows 8 Home Premium OEM
Optical Drive: Lite-On
http://pcpartpicker.com/p/Fj8y
He would preferably like to stay around 1300 dollars. Thanks for the help.
i7 3770k @ stock | Hyper 212 evo | Crucial Low Profile 8GB @ 1600 MHz | MSI 7950 | MSI GD-65 | OCZ ZT 750w | Bitfenix Shinobi Window | WD Blue 1TB | Samsung 840 240GB | CM Storm Trigger Blue Switches | Razor Death Adder
https://linustechtips.com/topic/5355-friends-build/
Also it doesn't look like you need a full tower case like that. You could save like $70 and get something like a Fractal Design Define R4 or a BitFenix Shinobi Window. Both cases have a white version but if you really like how the Switch looks then go for it.
https://linustechtips.com/topic/5355-friends-build/#findComment-61278
heres a some what new build it just has a different gpu gtx 680 and a different case otherwise I would recommend dropping the SSD for an. Also Windows 8 isn't good for gaming recommend Windows 7 http://pcpartpicker.com/p/FlB9
crap I meant to say drop the SSD for a HDD for more space
Project Restomod (In progress)
https://linustechtips.com/topic/5355-friends-build/#findComment-61346
Seeing as the next gen consoles will be kicking AMD parts the near future of games will be heavily optimized for such rigs, and as crysis 3 can actually utilize 8 cores (the benchmarks really show it) I think it's a good idea to be building AMD rigs.
Here is what i'd recommend: http://pcpartpicker.com/p/FlIo & no to windows 8, just... just no!
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/5355-friends-build/#findComment-61351
Gaming performance is about the same on W8 vs W7.
https://linustechtips.com/topic/5355-friends-build/#findComment-63137
- I would recommend switching out the GPU for a 7970 if he is just gaming. I'd only keep the GTX 670 if your friend will benefit from CUDA which I doubt he will.
- You should get about a 600W power supply as the 7970's can pull a lot of power once overclocked, I'd recommend a Rosewill HIVE 650W for an additional $20. It's a great power supply, very high quality and semi-modular.
- Does he really need the full sized tower, NZXT Source 810? I'd recommend getting a mid-tower such as the Fractal Design Define R4 for $110 with the window, minus $10 without the window. It's a great case, silent, looks very nice and is worth your money. Another choice would be the NZXT Phantom 410, or if you wanted a full tower then an NZXT Phantom Full Tower is also a good choice. All cases are around the $100-$120 mark.
- You may want to get some low profile RAM as the big heatspreaders on that Vengeance can conflict with coolers.
Hope that helps you out!
https://linustechtips.com/topic/5355-friends-build/#findComment-63346
