I am within the last few months of saving up for a much needed upgrade. Within the past couple of days, I have noticed that my ram usage has skyrocketed. I am currently idling between 60% and 90%, and when doing anything (like browsing the web, or playing games), i get between 97% and 100% (at which point, my screen, and second monitor shut off). The following screenshots are of my task manager on the performance tab, showing ram usage, and the processes tab, sorting by memory usage highest to lowest, respectively. EDIT In these pictures, I am only running this tab on chrome, the task manager, skype, and a screen shot program called Greenshot.
Currently using a Toshiba Satellite (not sure about the model number) from 2012
Intel Pentium b960 with Intel integrated graphics (no number following it) running at 2.20 GHz
300 GB of internal storage (HDD) (not the original one, I had to replace it) w/ a 500 GB external hard drive (HDD)
4 GB of DDR3 ram
Running Windows 10, 64 bit
I think my problem is with system taking up so much ram, but i don't know how to lower it, I am thinking of doing a clean install of Windows, but want to make sure I've tried everything.
Any help would be greatly appreciated, thanks  :)
https://linustechtips.com/topic/535438-ram-usage-problems/
stop skype running and that should help some. do a clean install. also can you upgrade the ram
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/535438-ram-usage-problems/#findComment-7103185
