1.I have an R9 380 by Sapphire. It's 1010MHz on stock and i pushed it to 1050MHz with +10% on the power limit. I got +6 AVG FPS, and I wonder if i can get around +15. If i push it to 20% and try around 1100MHz and I see artifacting, will that damage my card?
2.Ways to damage a card during overclocking? Voltages? Setting GPU clock to max?
3.Will overclocking the memory clock have any noticeable increase in FPS?
I'm using MSI Afterburner. I'm new to OC'ing, help me  :blink:
https://linustechtips.com/topic/535413-overclocking-questions/
1. if you see artifacting at 1100mhz, it means the overclock is unstable. back it off a little bit.
2. too much voltage, but you don't really damage it cuz its limited.
3. it will a bit, but its the core that will affect it most.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/535413-overclocking-questions/#findComment-7102832
Cant really damage a card through overclocking (minus too much heat(or extreme voltages), but it thermal throttles still), games crash when you card is unstable.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/535413-overclocking-questions/#findComment-7102834
Much thanks! I'll see how fan my card can go.
https://linustechtips.com/topic/535413-overclocking-questions/#findComment-7102929
