Low-Medium Server/NAS build
Hi, i am planning to build a Server that supports about 40 TB of data maximum, although i will begin with 2TB+500GB+2TB using 2/3TB drives. I am thinking about using also a 250 GB hard drive as a boot device.
The server would be used to backup about 4-5 computers daily, store more than 500GB of photos and go pro videos and to store documents, movies, 1.5TB HD audio files and other files.
I would also run on it a Windows 7 VM and a VPN service to access to my LAN while i'm not at home. In the future i could also want to host a small web site.
Could you help me to find out a low cost configuration for my needs?
I can spend a maximum of 230€ (about 250$) for cpu, ram and mobo.
Can you suggest me also a cheap case?
All the drives are excluded from the budget.
I was thinking to start with a low cost upgradable configuration, to be able to expand it in the future.
I would love to raid at least some drives (the ones with photos and videos) but i think it would cost very much...
Do you have some suggestions on the OS? Linus suggests unRAID, but i've also herd well about FreeNAS.
Thank you in advance,
F.
no.
no you cant do that.
none of what you said besides MAYBE the file server will work at that price.
What you want is $2k
especially if going with someone decent ( like freenas)
and believe me $2k would be pushing it.
