Hi guys,
Mate looking to have a 'breath effect' in the base of his 800D. We've looked at a few options and the Aquaero is looking possible.
We've tried the phobya controller, but that's not working out (only white will pulse, none of the colours, and it goes fully off which is not wanted).
We've tried making our own with a bread board, transistor and other bits I know nothing about, but that's not working too well and can't change speed automatically.
Wondering what suggestions you guys have and if anyone's used/got an Aquaero 5, can it make LEDs 'pulse' and how controllable is it (speed, max brightness, min brightness) and can it change the speed given an input (CPU clock speed, CPU load, CPU temp whatever)?
The Aquaero would be great because we could then hook the pump and fans up aswell as he's looking for a system that'll be <inaudible with day-day workloads.
As always, help would be appreciated.
CPU: FX 6300 @ stock Mobo: Gigabyte 990FX UD5 v3.0 GPU: 1 x R9 290 4GB RAM: 24GB DDR3 1600 SSD: Kingston HyperX 3K 120GB HDD: 1 x 1TB & 1 x 500GB PSU: BeQuiet PowerZone 1000W Case: Coolermaster Elite 370 (upside down due to lack of stick thermal pads for memory heatsinks) CPU Cooler: Thermalright Ultra Extreme 120 GPU Coolers: Thermalright HR03-GT Fans: 5 x Akasa Apache Blacks, 1 x Corsair 120mm SP HP (GPU) & 1 x Noctua 92mm
Most of this was from mining rig, hence the scewy specs (especially PSU)
https://linustechtips.com/topic/53496-led-breath-effect-controller-help/
Lian Li PC-V359WRX Micro-ATX Case | Intel 5960X Extreme 3.00GHz | ASRock Fatal1ty X99M KILLER | Crucial 32 GB 2666 DDR4 | Thermaltake NiC C5 | EVGA Supernova 1200W P2 | 2x 240GB OCZ Radeon R7 | 2x 256 GB Samsung 840 Series Pro | 2 X 120GB Samsung 840 EVO | 6x NF-F12’s | Place Holder GPU R9 290X |
Links Current 5960X Old FX9590
Already seen, when wired wouldn't work right and doesn't allow automatic adjustment given system load.
