Do you want or care about a color scheme.
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/534775-ram-decision-help/#findComment-7095262
Corsair Venegence LPX or Kingston HyperX Fury Black/White would look really nice.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/534775-ram-decision-help/#findComment-7095281
No
Do not care about looks or color scheme
Cheapest will be just fine then!
https://linustechtips.com/topic/534775-ram-decision-help/#findComment-7095293
No
Just go for the cheapest.  I think there are cheaper sticks of ram that have black PCB's so they won't stand out like the green.
https://linustechtips.com/topic/534775-ram-decision-help/#findComment-7095299
