I'm really not sure about this question I need some help if possible.
I know that the parallel axis theorem is I = Icentre + mx^2 , I don't understand part C where it asks the moment of interia if it doesn't lie on the axis of the rod how can it be affected as there is no mass there.
https://linustechtips.com/topic/534575-maths-help-please/
It's so that you can do part d.
CPU: Intel i7 3970X @ 4.7 GHz  (custom loop)   RAM: Kingston 1866 MHz 32GB DDR3   GPU(s): 2x Gigabyte R9 290OC (custom loop)   Motherboard: Asus P9X79
Case: Fractal Design R3    Cooling loop:  360 mm + 480 mm + 1080 mm,  tripple 5D Vario pump   Storage: 500 GB + 240 GB + 120 GB SSD,  Seagate 4 TB HDD
PSU: Corsair AX860i   Display(s): Asus PB278Q,  Asus VE247H   Input: QPad 5K,  Logitech G710+    Sound: uDAC3 + Philips Fidelio x2
HWBot: http://hwbot.org/user/tame/
https://linustechtips.com/topic/534575-maths-help-please/#findComment-7092777
