So i was making this computer for someone and i put a xfx 430w proseries or something like that in their pc. Anyways we had a power cut as i was installing windows, my own pc, my fathers and my brothers all shut down and the Nintendo wii dramatically ejects its disc(i dunno why). The power cut was for just under 10 seconds but the pc stayed on weirdly. Any ideas as to what happened.
Listen if you care.
https://linustechtips.com/topic/53451-xfx-ran-without-power/
The capacitors were charged, therefore you wouldn't have lost anything if it was only for a short amount of time.
https://linustechtips.com/topic/53451-xfx-ran-without-power/#findComment-717457
I didnt think capacitors would of lasted ten seconds, i guess that was down to luck. I doubt i could do it again. Its surprising as my fathers pc has a cx430 in it and i heard that the cx430 and the xfx 430w use the same parts.
Listen if you care.
https://linustechtips.com/topic/53451-xfx-ran-without-power/#findComment-717466
You'd be surprised, but it honestly depends on the caps used as PSUs can stay charged for a short amount of time while the PSU isn't powered directly.
https://linustechtips.com/topic/53451-xfx-ran-without-power/#findComment-717472
Nothing new
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/53451-xfx-ran-without-power/#findComment-717498
