is there a known name for it?
is there one that exists thats just very small or compact right angle?
Im not sure. I used to have a laptop that would stop charging from time to time because of this. I had to solder it and tape it together it was working ever since until it was ready for trashbin.
https://linustechtips.com/topic/534357-power-supply-cable/#findComment-7090179
Like a right angle C13 cable?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/534357-power-supply-cable/#findComment-7090194
possibly yes but smaller
AFAIK that's as small as you can get them cause safety standards
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/534357-power-supply-cable/#findComment-7090242
