Computer crashed wont turn back on. Help!
Go to solution Solved by pedro69,
It did not work guess I will start with switching out the components so should I replace the PSU first?
If you don't see any visible issues with the Mobo (i.e. bulged capacitors) I would start with the PSU. You can do a basic test by shorting the black and green connector on the 24 pin:
To do a basic test disconnect everything from the PSU, put a paper clip in the two connectors (see photo) and flip on the power switch in the back of the PSU. Check if the fan turns on on the PSU, but please be aware that some PSU have 0 rpm when on idle so you might need something else connected to see if it gets stable power (i.e. connect a fan to a molex connector on the PSU).
So my problem is that my PC that I built at the end of November last year just crashed randomly while I was just browsing internet doing my own thing. I have no idea what the heck caused it it just turned off and won't turn on anymore.
When I try to rurn it on only the fans turn on for a split second and nothing else happens though my motherboard rgb lights and my keyboard backlight turn on when its plugged in. Also I can do the fan test with my Corsair rm750i PSU.
Pls help I've got no Idea what to try right now.
My system specs:
CPU: Intel Skylake I5 6600k @ 3.5GHz
Motherboard: Asus Maximus VIII Hero
Ram: Corsair Vengeance LPX 2666MHz @ stock speed
GPU: Sapphire Nitro R9 390 @ stock speed
PSU: Corsair RM750i
If you need any more info just ask.
Thx everyone in advance.
https://linustechtips.com/topic/533687-computer-crashed-wont-turn-back-on-help/
My system specs:
PSU: Corsair RM750i
try using the built in "gpu" of intel, if nothing happens, try if your hard drive works in another system if you can, more than that... try to clear cmos or rest the bios by...well you got a switch for that oin the Maximus VIII i believe.
hope this helps a bit  ^_^
┏(◑̃.◑̃)┛ Totally Not Dangerous ┏(◐̃.◐̃)┛
i7 4790K / 16GB RAM \ 250GB SSD
Using the built in one does not seem to do anything should I unplug the R9? Pushing the reset cmos only spins the fans around for a split second.
Can't try my hard drives anywhere else its the only desktop in the house.
probably the power supply..., as the fans spin, you get power (from somewhere, the psu) but it dont "hold it" and just goes off again. its weird to see the RMi (maybe) fail as that.
i dont think its the motherboard...dont you got any error code thing on the Maximus VIII?
I don't think it is the PSU as it would not be able to provide or hold power if it had gone.
Gaming PC: Case: NZXT Phantom 820 Black | PSU: XFX 750w PRO Black Edition 80Plus Gold (Platinum) | CPU: Intel Core i5 4690K | CPU Cooler: BE QUIET! Dark Rock Pro 2 | MB: ASUS Sabertooth Z97 Mark S | RAM: 24GB Kingston HyperX and Corsair Vengeance 1866MHz | GPU: MSI R9 280X 3G | SSD: Samsung 840 Evo 250GB | HDD: 9TB Total | Keyboard: K70 RGB Brown | Mouse: R.A.T MMO7
Laptop: HP Envy 15-j151sa | 1920x1080 60HZ LED | APU: AMD A10-5750M 2.5GHZ - 3.5GHZ | 8GB DDR3 1600mhz | GPU: AMD  HD 8650G + 8750M Dual Graphics | 1TB SSHD
Here are 2 videos to show what happens when I try to turn it on and when I press clear cmos:
In low res:https://youtu.be/PItM-emNFM8
In 4k:https://youtu.be/KRit8h8YQFQ
I removwd the GPU and switched it to the integrated processor gpu.
You can try the following:
  1. Take out your RAM, unplug the PSU from the wall and hold down the power button down for about 20 seconds.
  2. Put the RAM back in, reconnect the power and check if it turns on now.
If this doesn't work it's time to start swapping components and I would start with the PSU. If the PSU works it's most probably the Mobo (check for bulged capacitors).
  • Take out your RAM, unplug the PSU from the wall and hold down the power button down for about 20 seconds.
  • Put the RAM back in, reconnect the power and check if it turns on now.
The PSU has a fan test button on it which spins the fan in it. Or should I use your method?
When I press the fan test then the fan spins.
I would use my method because with that you can be sure it will test the PSU and not only the fan. Just be careful to not short the wrong pins.
Your PSU is definitely 0 rpm on idle so if you have a fan with a molex connector I would hook it up to see if it gets stable power.
Unfortunately I don't own a fan with a molex connector and I am not sure which pin is wich because all my cables are black.
You can also go by location of the pins (compare with photo). Make sure the connector has the same orientation and bridge the pins to the left of the latch.
To check you can also use a Multi-meter if you have one, check on a molex connector - either black & yellow (12V) or black & red (5V).
Okay I tried your method and got about 0.75 V on the Multi- meter on the 20V setting.
Thats not normal is it?
Here is a diagram of a molex connector:
57763d1366655268-dubbio-sul-neon-dentro-
When measuring at the black (negative) and yellow (positive) pins you should get a relatively stable 12 Volts reading on the multi meter. 0.75V is way to low and might indicate your PSU went south.
If you have the chance to test your rig with another PSU (friend or family for example) I would recommend it before buying a new one though.
Have you moved your Power switch or leds or anything whilst it was on? It could have shorted out yur MB and stuff. Try moving the cables around
Well there was that one time that my computer froze and I didn't know what to do so I turned the Psu off. I'd say about 2 days ago
On my Asus motherboard that happens when I don't hold down the power for 3 seconds (either the case button or on board button)
^this, first the problem was the motherboard now the power supply.. if your computer froze, press down hold it the power button on your case TILL it shuts off.. NEVER EVER EVER EVER EVER EVER turn off the psu when the computer is on NEVER EVER EVER dont ever do it again.. your pc needs time to shutdown..
i have the same problem but for me its because there was a power outage in my area, turns off my psu, first it works for like a day or two and then suddenly computer wont turn on again, bought the psu tester and motherboard tester then on the psu tester not all the light turns on, bought a new psu and now works well
i7 4790k | GTX 980Ti | NOCTIS 450 & Hue+ | 1tb Seagate HDD + 120gb Kingston SSD (OS) | EVGA SUPERNOVA 750w GOLD2 80+ | WINDOWS 10 PRO (not upgrade) | 3dMARK Score: http://www.3dmark.com/fs/7330332
Guess the same(or something similiar) happened to me but at my own fault.
well it might not be the psu, get the psu tester (and motherboard tester they both are different thing) if you can from ebay, amazon or your local tech/pc component shops to test your psu or motherboard if its good or bad dont worry the tester will come with the instruction so you will know what it says/means what each lights represents when its on or off on the tester! hope it helps!
