can't map network drive - help?
By
warmmilk
in Networking
in Networking
Solved by Thingo,
It sounds to me, like the network settings, on your file share computer, has file sharing Turned off.
Try this
Open Control panel
Network and internet
Network and sharing center
Left side, pick "Edit advanced sharing"
Activate File and printer sharing.
If this doesn´t do the trick, maybe you should check if the shared folder's, sharing seetings are correct.
derekchan ·
Posted in New Builds and Planning4 -
5
1
5
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting7 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
