A better replacement for my HyperX Cloud mic?
Solved by lkarej,
As far as I'm aware decent mics cost a fair chunk of cash.
Same thing happened to my mic on my cloud's. Except instead of static it would random boost to 100000* in volume and then stopped working altogether.
I was planning on ordering some stuff on amazon so I just added a Blue yeti that was on sale to my cart.
Anyways if you want something on the headset IIRC Modmic is your only choice. Maybe Kingston HyperX sells replacements?
