GTX hybrid kit
Go to solution Solved by Josephdalepi,
So is it yes or a no or what did I do any real harm
probably not enough to ever notice, but the heat is dispersed across the entire fin, so screwing into it did do just the tiniest bit
may be worse, but i kinda doubt it
When installing my hybrid kit fan on the rad I screwed into the fins but here is no tube that is behind it. I don't think it will effect anything because no air travels through that piece of the radiator am I right to assume this I did it on all four screw holes?
may not be the best idea, but it should be ok
this makes me cringe hard though
https://linustechtips.com/topic/532777-gtx-hybrid-kit/#findComment-7071452
