Hi
I built myself a system and it was my first one since 8 years ago that I switched to using Laptops.
The issue I am having right now is:
The very first time after shutting down the system, I press the power button the system does turn on and I see the loading then suddenly it shuts down the system.
However if I press the power button again immediately or later on the system does turn on and boots up its all good after that.
Here are the list of the components I used:
1-ASUS ROG MAXIMUS VIII HERO
2-Intel Core i7-6700K
3-Corsair Cooling Hydro Series H110i GTX
4-Kingston 16 gigabytes KIT DDR4 2800MHz CL14 HyperX Savage Black
5-ASUS MATRIX-GTX980TI-P-6GD5-GAMING
6-Samsung 850 to 256 gigabytes
7-Western Digital Black 1000 gigabytes 64 megabytes cache with Advanced Format
8-Corsair RM1000i
And I am using Windows 10pro 64bit
I have no idea why this is happening please help if you know anything.
Thank you
https://linustechtips.com/topic/532261-help-new-pc-boot-problem/
Oddly a lot of people seem to be experiencing the same I did a while ago... I think it might be driver related...
Anyway changing from VGA cable to HDMI cable fixed the reboot problem with me...
Think about it... AMD released a crimson driver a while back... a lot of people complained saying their gpu chips were getting hotter... and we all know that can result into damage... So I guess its best to turn off the automatic updates for your hardware so no one can screw up the stability of your equipment and force you to upgrade.
https://linustechtips.com/topic/532261-help-new-pc-boot-problem/#findComment-7064903
Maybe it's problem with the psu
CPU - i5-8400 , Motherboard - ASROCK Z370 Killer SLI, RAM - 2x8 GB DDR4 2400mhz , GPU - EVGA GTX 950 SC, Case - SilentiumPC PAX M70 Pure Black V2 Storage - 240GB SanDisk SSD, 1TB WD Blue, PSU - bequite! 600w Pure Power 10, Display - Dell P2417H, Cooling - bequiet! Pure Rock, Keyboard - Viper V730, Mouse - natec Genesis G55, Sound - Philips MCD712, OS - Windows 10 Professional 64-bit
https://linustechtips.com/topic/532261-help-new-pc-boot-problem/#findComment-7064958
Thanks guys,
I also think its an software issue however its not only that I had problem installing the CPU cooler didn't recognized it.
Also having some issues with my keyboard which seems to come from the windows.
Gonna turn off the updates, actually I did update the Bios and nothing changed
I totally forgot about this one, last night the system was working and I was playing games on it suddenly the monitor went to power saving mode but everything else was going on I did have the sound
couldn't do anything but to restart
https://linustechtips.com/topic/532261-help-new-pc-boot-problem/#findComment-7072876
